    2. Patrick_Salvino
    P
    • 继续与 Patrick_Salvino 聊天
    • 开始与 Patrick_Salvino 的新会话
    Patrick_Salvino 发布的帖子
    • RE: FR8003A 蓝牙连接间隔之间的底电流如何优化?
      Well, there are many points to consider—some outside the MCU, and others within it. If you send your circuit schematics here, I can list them out for you.
      P
      Patrick_Salvino
    • FR8003A Reset Cause
      I have been unable to find any API or CPU reset status register that would allow reading the cause of the reset upon device power-up. Please advise.
      P
      Patrick_Salvino
    • RE: FR800x Power Management Unit (PMU)
      The issue is solved.
      P
      Patrick_Salvino
    • RE: FR8003A Unwanted Wake-up at 64 seconds
      My current SDK version is 1.4
      The issue is that the Bluetooth Stack wakes the MCU up every 64 seconds (periodically ). Why is this happening?
      P
      Patrick_Salvino
      @mars Do you mean that it is not possible to put the system into an indefinite sleep mode? I want the microcontroller (MCU) to wake up only when a specific event occurs (one that is not time-based).
      P
      Patrick_Salvino
    • FR800x Power Management Unit (PMU)
      I am using the sleep mode on the FR8003A chip. When I use the RTC wake-up feature, the Bluetooth stack functions correctly after waking up; however, when I use the button (GPIO pin) to wake the device, the Bluetooth stack malfunctions (the MCU wakes up upon pressing the button, but Bluetooth functionality is impaired thereafter). What is the issue? Could someone explain the correct procedure for entering and exiting sleep mode to ensure Bluetooth operates properly after wake-up?
      P
      Patrick_Salvino
    • FR800x SDK Versions
      According to the official FREQCHIP website (https://www.freqchip.com/fr800x), a new version of the SDK was released in August 2026; however, I could not find any release notes or a changelog for it. How can I find out about the changes or improvements made compared to version 1.4?
      P
      Patrick_Salvino
      Thanks a lot. I also have another issue. When I put the MCU to sleep and enable the wake-up by a push button, the wake-up occurs but the Bluetooth stack does not work! I do the wake-up mechanism just like the sample projects, What am I missing here?
      P
      Patrick_Salvino
    • FR8003A Unwanted Wake-up at 64 seconds
      When I put the FR8003A in sleep mode with Bluetooth stack initialized and all wake-up mechanisms disabled, the MCU wakes up after 64 seconds. How can I prevent this unwanted wake-up? I want to wake it up only via a button and this part works properly.
      P
      Patrick_Salvino
    • FR8003A TRNG unit driver
      Hi everybody, I need to use the TRNG unit in FR8003A but I can't find its driver inside the SDK folder. Please help me find it. Thanks.
      P
      Patrick_Salvino
    • RE: FR800x系列FAQ
      @zr
      Great. Thanks a lot.
      I'm not sure if I should ask each question in a separate post or not, so for start:
      1. It seems that Dinamic Memory Allocation is not available by default, the heap memory section in the scatter file is not being recognized by the compiler due to different naming:
        .\Objects\ble_simple_peripheral.axf: Error: L6218E: Undefined symbol __heap_base (referred from malloc.o).
        .\Objects\ble_simple_peripheral.axf: Error: L6218E: Undefined symbol __heap_limit (referred from malloc.o).
        I tried using os_malloc() and it's not able to allocate memory and returns NULL.
        It seems that the heap section is not specified correctly in the scatter file. Please help me out about this issue. Thanks.
      2. According to the SDK user's guide PDF file, the maximum paired devices count is 20 in GAP bond manager, but the SDK failes for values higher than 8 and causes the application crash.
      P
      Patrick_Salvino
    • RE: FR800x系列FAQ
      @zr Thanks. I also have some technical questions about the SDK, where should I ask them?
      P
      Patrick_Salvino
    • RE: FR8003A SDK latest version
      @felix-yang
      Thanks @felix-yang but the SDK version numbers in the official website doesn't match the numbers specified by the users here in this forum.
      I have some technical questions:
      P
      Patrick_Salvino
    • FR8003A SDK latest version
      What is the FR8003A SDK latest version? Where can I download it?
      It seems that the version on the official website is outdated and belongs to the Keil MDK 4 generation which is obsolete.
      P
      Patrick_Salvino
    • RE: FR800x系列FAQ
      Hi. Good day. I need the FR8003A SDK (latest version).
      您好,祝您今天愉快。我需要FR8003A SDK(最新版本)。
      P
      Patrick_Salvino
