    2. lakesky
    L
    • 继续与 lakesky 聊天
    • 开始与 lakesky 的新会话
    lakesky
    @lakesky
    lakesky 关注
    lakesky 发布的帖子
    • RE: FR3068E-D开发板驱动RGB屏幕问题
      环境:使用sdk版本为 FR30XXC-SKD-v0.3.2 所用例程(ble_simple_periphreal) 参考工程为v0.2.3 例程(evb_demo)
      问题1:用版本v0.3.2 的函数psram_init 初始化不通过 但是使用v0.2.3中的psram_init 替换后能正常初始化 且测试数据正常
      相关代码:
      //前提 main.c 内初始时钟(hw_clock_init)正常 否则(psram_init)会一直卡在初始化中
      //相关时钟初始如下:
      __RAM_CODE void hw_clock_init(void)
      #if 0
      	System_ClkConfig_t sys_clk_cfg;
          sys_clk_cfg.SPLL_CFG.PLL_N = 8;
          sys_clk_cfg.SPLL_CFG.PLL_M = 0;
          sys_clk_cfg.SPLL_CFG.PowerEn = 1;
          sys_clk_cfg.MCU_Clock_Source = MCU_CLK_SEL_SPLL_CLK;
          sys_clk_cfg.SOC_DIV = 1;
          sys_clk_cfg.MCU_DIV = 1;
          sys_clk_cfg.APB0_DIV = 1;
          sys_clk_cfg.APB1_DIV = 1;
          sys_clk_cfg.APB2_DIV = 1;
          System_SPLL_config(&sys_clk_cfg.SPLL_CFG, 1000);
          System_MCU_clock_Config(&sys_clk_cfg);
      #else
          System_ClkConfig_t ClkConfig;
          /* CORE HSCLK Config */
          ClkConfig.CORE_HSCLK_CFG.CORE_HSCLK_Source = CORE_HSCLK_SEL_HES;
          /* PLL clock = HSE_VALUE*N + (HSE_VALUE/65535)*M */
          /* SPLL CLK Config */
          ClkConfig.SPLL_CFG.PowerEn = PLL_POWER_ENABLE;
          ClkConfig.SPLL_CFG.PLL_N = 9;
          ClkConfig.SPLL_CFG.PLL_M = 0;
          /* AUPLL CLK Config */
          ClkConfig.AUPLL_CFG.PowerEn = PLL_POWER_ENABLE;
          ClkConfig.AUPLL_CFG.PLL_N = 8;
          ClkConfig.AUPLL_CFG.PLL_K = 0;
          ClkConfig.AUPLL_CFG.PLL_D = 0;
          System_CORE_HSCLK_config(&ClkConfig.CORE_HSCLK_CFG);
          if (System_SPLL_config(&ClkConfig.SPLL_CFG,200) == -1)
              while(1);
          if (System_AUPLL_config(&ClkConfig.AUPLL_CFG,200) == -1)
              while(1);
          ClkConfig.MCU_Clock_Source = MCU_CLK_SEL_SPLL_CLK;
          ClkConfig.SOC_DIV  = 1;    /* This parameter is valid when MCU_Clock_Source == MCU_CLK_SEL_SPLL_CLK */
          ClkConfig.MCU_DIV  = 1;
          ClkConfig.APB0_DIV = 1;
          ClkConfig.APB1_DIV = 1;
          ClkConfig.APB2_DIV = 1;
          System_MCU_clock_Config(&ClkConfig);
      #endif
          __SYSTEM_UART_CLK_SELECT_SPLL();
          __SYSTEM_SPI_MASTER1_X8_CLK_SELECT_SPLL();
      static void display_psram_init(void)
      		pmu_psram_power_ctrl(true);
      		system_delay_us(1000);
      		if(psram_init(PSRAM_CLK_SEL_AUPLL))
      				printf("hw_psram_init\r\n");
      		else
      				printf("hw_psram_err\r\n");
      		#if 1
      			__CACHE_FLUSH(CACHE);
      			__CACHE_BANK_FLUSH(CACHE);
      			while (__CACHE_BANK_FLUSH_DONE(CACHE) == false);
      			__CACHE_WR_MODE_SET(CACHE, CACHE_WR_WRITE_THROUGH);
      			__CACHE_ADDR_RANGEx_BANK_SET(CACHE, 0, 0x00000000 >> 16);
      			__CACHE_ADDR_RANGEx_MASK_SET(CACHE, 0, 0x001F);
      			__CACHE_ADDR_RANGEx_POL_SET(CACHE, 0, CACHE_POL_CACHABLE);
      			__CACHE_ADDR_RANGEx_ENABLE(CACHE, 0);
      			__CACHE_ENABLE(CACHE);
      		#endif
      		// test psram write & read
      //		uint16_t *test_psram = (uint16_t *)PSRAM_DAC_BASE;
      //		for(uint32_t i = 0; i < 100; i++)
      //				test_psram[i] = 0xF800;
      //		printf("\r\n");
      //		for(uint32_t i=0;i<(100);i++)
      //				printf("%04x",test_psram[i]);
      //		printf("\r\n");
      函数:psram
      // v0.3.2
      __RAM_CODE bool psram_init(enum psram_clk_sel_t clk_sel)
          GPIO_InitTypeDef    GPIO_Handle;
          uint32_t ref_clk;
          if (clk_sel >= PSRAM_CLK_SEL_MAX) {
              return false;
          switch (clk_sel) {
              case PSRAM_CLK_SEL_COREH:
                  __SYSTEM_OSPI_CLK_SELECT_COREH();
                  ref_clk = 24000000;
                  break;
              case PSRAM_CLK_SEL_SPLL:
                  __SYSTEM_OSPI_CLK_SELECT_SPLL();
                  ref_clk = system_get_SPLLCLK();
                  break;
              case PSRAM_CLK_SEL_AUPLL:
                  __SYSTEM_OSPI_CLK_SELECT_AUPLL();
                  ref_clk = system_get_AUPLLCLK();
                  break;
              default:
                  return false;
          __SYSTEM_OSPI_CLK_ENABLE();
          /* clock of AHB cache should be enabled before access psram */
          __SYSTEM_AHBC_CLK_ENABLE();
      #if PSRAM_IO_GPIO == 1
          GPIO_Handle.Pin       = GPIO_PIN_12|GPIO_PIN_13;
          GPIO_Handle.Mode      = GPIO_MODE_AF_PP;
          GPIO_Handle.Pull      = GPIO_NOPULL;
          GPIO_Handle.Alternate = GPIO_FUNCTION_9;
          gpio_init(GPIOB, &GPIO_Handle);
          GPIO_Handle.Pin       = GPIO_PIN_2|GPIO_PIN_3|GPIO_PIN_5|GPIO_PIN_6;
          gpio_init(GPIOC, &GPIO_Handle);
      #else
          SYSTEM->OspiPadConfig.OSPI_FuncMux = 0xFDF55FFD;
      #endif
          if(psram_delay == 0xFF)
              qspi_stig_cmd(PSRAM_OSPI_IF, reset_enable_cmd, QSPI_STIG_CMD_EXE, 0, NULL);
              qspi_stig_cmd(PSRAM_OSPI_IF, reset_cmd, QSPI_STIG_CMD_EXE, 0, NULL);
      #if PSRAM_ENABLE_Q_MODE == 1
              psram_enter_quad();
      #endif  // PSRAM_ENABLE_Q_MODE == 1
          /* about 100 bytes can be transmitted during 8us when QSPI clock is 24MHz */
          ref_clk /= ((PSRAM_CLK_DIV_SEL+1) * 2);
          uint32_t bytes = ref_clk / 240000;
          uint32_t boundary_cfg = 1 << (31 - __CLZ(bytes));
          if (boundary_cfg >= 0x100) {
              boundary_cfg = 0x100;
          psram_controller_init(boundary_cfg);
          if(psram_delay != 0xFF)
              __QSPI_READ_CAPTURE_DELAY_SET(PSRAM_OSPI_IF, psram_delay);
          }else{
              /* detect read capture delay configuration */
              uint8_t delay_lower, delay_upper, index;
              *(volatile uint32_t *)(PSRAM_DAC_BASE) = 0x5a5a5a5a;
              while(__QSPI_IS_BUSY(PSRAM_OSPI_IF));
              for (index = 0; index < 16; index++) {
                  __QSPI_READ_CAPTURE_DELAY_SET(PSRAM_OSPI_IF, index);
                  if (*(volatile uint32_t *)(PSRAM_DAC_BASE) == 0x5a5a5a5a) {
                      break;
              if (index == 16) {
                  __SYSTEM_OSPI_CLK_DISABLE();
                  __SYSTEM_AHBC_CLK_DISABLE();
                  return false;
              else {
                  delay_lower = index;
              for (; index < 16; index++) {
                  delay_upper = index;
                  if (*(volatile uint32_t *)(PSRAM_DAC_BASE) != 0x5a5a5a5a) {
                      break;
              psram_delay = ((delay_lower + delay_upper)>>1);
      //    printf("0x%02x, %d.\r\n", 1 << (31 - __CLZ(bytes)), (delay_lower + delay_upper)/2);
          return true;
      // v0.2.3
      //__RAM_CODE
          uint32_t ref_clk;
              return false;
          switch (clk_sel) {
                  ref_clk = 24000000;
                  break;
                  break;
                  break;
              default:
                  return false;
      #else
          SYSTEM->OspiPadConfig.OSPI_InputOpenCircuit = 0xffffffff;
          SYSTEM->OspiPadConfig.OSPI_WakeupEN = 0;
      #endif
          psram_enter_quad();
                  break;
          if (index == 16) {
              return false;
          else {
                  break;
          __QSPI_READ_CAPTURE_DELAY_SET(PSRAM_OSPI_IF, (delay_lower + delay_upper)>>1);
          return true;
      问题2: v0.3.2 dma 传输数据异常 且dma_start_IT当地址指向为 (uint32_t)&hdisplay.DISPLAYx->TX_FIFO 时无法触发中断
      // 初始化
      		__SYSTEM_DMA0_CLK_ENABLE();
      		/* DMA Init */
      		system_dmac_request_id_config(DISPLAY_TRANS,DMA0_REQUEST_ID_2);
      		dma_handle.DMAx                       = DMA0;
      		dma_handle.Channel                    = DMA_Channel1;
      		dma_handle.Init.Data_Flow             = DMA_M2P_DMAC;
      		dma_handle.Init.Request_ID            = 2;
      		dma_handle.Init.Source_Master_Sel     = DMA_AHB_MASTER_2;
      		dma_handle.Init.Desination_Master_Sel = DMA_AHB_MASTER_3;
      		dma_handle.Init.Source_Inc            = DMA_ADDR_INC_INC;
      		dma_handle.Init.Desination_Inc        = DMA_ADDR_INC_NO_CHANGE;
      		dma_handle.Init.Source_Width          = DMA_TRANSFER_WIDTH_16;
      		dma_handle.Init.Desination_Width      = DMA_TRANSFER_WIDTH_16;
      		dma_handle.Init.Source_Burst_Len      = DMA_BURST_LEN_32;
      		dma_handle.Init.Desination_Burst_Len  = DMA_BURST_LEN_32;
      		dma_init(&dma_handle);
          /* panel spec: DCLK/HSYNC/VSYNC negative, DE active high */
      		NVIC_ClearPendingIRQ(DMA0_IRQn);
          NVIC_EnableIRQ(DMA0_IRQn);
      // 使用
      void rgb_demo(enum_RGB_Demo_t fe_Demo)
      		display_psram_init();
      		rgb_panel_init();
      		display_psram_buff = (uint16_t *)PSRAM_DAC_BASE;
      		for(uint32_t i = 0; i < RGB_ROW * RGB_COL; i++)
      				display_psram_buff[i] = LCD_COLOR_RED;
      		printf("+++++%04x+++++++",display_psram_buff[53]);
          switch(fe_Demo)
              case RGB_INTERACTION_DMA:
                  printf("RGB demo: solid color with DMA start\r\n");
                  __DISPLAY_RGB_ENABLE(hdisplay.DISPLAYx);
      						uint16_t buffl[64];
      						dma_start_IT(&dma_handle, (uint32_t)display_psram_buff, (uint32_t)&hdisplay.DISPLAYx->TX_FIFO, 64);
      						// for(uint16_t i =0;i<64;i++)
      						// 		printf("%04x",buffl[i]);
      //						xTaskCreate(test_task, "test_task", 512, NULL, 2, &test_task_handle);
                  break;
      extern int fputc(int c, FILE *fp);
      __RAM_CODE void dma0_irq(void)
      		void * temp = NULL;
      		g_dma0_irq_cnt++;
          if (dma_get_tfr_Status(&dma_handle))
              dma_clear_tfr_Status(&dma_handle);
      				fputc('D',(FILE*)temp);
          if (dma_get_error_Status(&dma_handle))
              dma_clear_error_Status(&dma_handle);
      				fputc('E',(FILE*)temp);
      		g_dma0_irq_cnt++;
      当设置为:dma_start_IT(&dma_handle, (uint32_t)display_psram_buff, (uint32_t)buffl, 64);时 关掉buff1注释 打印如下
      有D 打印说明进入了中断
      当设置为:dma_start_IT(&dma_handle, (uint32_t)display_psram_buff, (uint32_t)&hdisplay.DISPLAYx->TX_FIFO, 64);
      没有打印 D
      v0.3.2 已经使用了psram当缓冲缓存数据 初始化相关文件 然后一包发送 但是使用逻辑分析仪抓取 pd12(lcd-g3) 没有波动 屏幕都不显示颜色了 持续刷屏也不显示颜色
      // 完整代码
      #include "fr30xx.h"
      #include "user_common.h"
      #include "FreeRTOS.h"
      #include "task.h"
      #include "driver_psram.h"
      typedef struct
          uint32_t VerticalSignalCount;
          unsigned char *rgb_TxData;
          uint32_t vs_tvw_count;
          uint32_t vs_back_count;
          uint32_t vs_front_count;
      }struct_RGB_TypeDef_t;
      DMA_HandleTypeDef dma_handle;
      DISPLAY_HandTypeDef hdisplay;
      struct_RGB_TypeDef_t rgb_handle;
      TaskHandle_t test_task_handle;
      volatile uint32_t g_dma0_irq_cnt = 0;
      #define LCD_COLOR_BLACK  0x0000
      #define LCD_COLOR_WHITE  0xFFFF
      #define LCD_COLOR_RED    0xF800
      #define LCD_COLOR_GREEN  0x07E0
      #define LCD_COLOR_BLUE   0x001F
      #define RGB_VBPD    16
      #define RGB_VFPD    16
      #define RGB_VSPW    4
      #define RGB_HBPD    8
      #define RGB_HFPD    8
      #define RGB_HSPW    4
      #define RGB_ROW     800
      #define RGB_COL     480
      #define DISPLAY_PSRAM_SIZE					(RGB_ROW*RGB_COL*2)
      #define LOAD_ORIG_FRAMEBUFFER       (void *)(PSRAM_DAC_BASE+ 60 + DISPLAY_PSRAM_SIZE)
      #define LOAD_LEFT_FRAMEBUFFER       (void *)(PSRAM_DAC_BASE+ 60 + DISPLAY_PSRAM_SIZE*2)
      #define LOAD_RIGHT_FRAMEBUFFER      (void *)(PSRAM_DAC_BASE+ 60 + DISPLAY_PSRAM_SIZE*3)
      volatile uint8_t refr_wait_sign = 0;
      static uint16_t *display_psram_buff;
      		else
      		#if 1
      		#endif
      //		printf("\r\n");
      //		printf("\r\n");
      static void test_task(void *arg)
          while(1) {
      //        printf("dma irq cnt=%d \r\n", g_dma0_irq_cnt);
      				display_rgb_write_data(&hdisplay,display_psram_buff,RGB_ROW * RGB_COL);
      				vTaskDelay(1000);
      static void rgb_panel_init(void)
      		/* init display CLOCK */
          __SYSTEM_DISPLAY_CLK_ENABLE();
      //    __SYSTEM_DISPLAY_CLK_SELECT_D48M();
      		__SYSTEM_DISPLAY_CLK_SELECT_SPLL();
          __SYSTEM_GPIOB_CLK_ENABLE();
          __SYSTEM_GPIOD_CLK_ENABLE();
          __SYSTEM_TIMER0_CLK_ENABLE();
      		printf("display clock:%d\r\n", system_get_peripheral_clock(PER_CLK_DISPLAY));
      		/* RGB io init */
      		GPIO_Handle.Alternate = GPIO_FUNCTION_8;
          GPIO_Handle.Pin       = 0xF00;
          GPIO_Handle.Pull      = GPIO_PULLUP;
          GPIO_Handle.Pin       = 0xFFFF;
          gpio_init(GPIOD, &GPIO_Handle);
          GPIO_Handle.Alternate = GPIO_FUNCTION_0;
          GPIO_Handle.Mode      = GPIO_MODE_OUTPUT_PP;
          GPIO_Handle.Pin       = GPIO_PIN_7;
          gpio_write_pin(GPIOB, GPIO_PIN_7, GPIO_PIN_SET);
      		/* RGB Interaction Init */
      		hdisplay.DISPLAYx = DISPLAY;
      		hdisplay.RGB_Init.RGB_OUT_FORMAT_SELECT = RGB565_OUT;
      		hdisplay.RGB_Init.RGB_IN_FORMAT_SELECT = RGB565_IN;
      		hdisplay.Interface_Select = DISPLAY_INTERFACE_RGB;
      			 RGB Timing Init
      		hdisplay.RGB_Init.HBP = RGB_HBPD;
      		hdisplay.RGB_Init.HFP = RGB_HFPD;
      		hdisplay.RGB_Init.VBP = RGB_VBPD;
      		hdisplay.RGB_Init.VFP = RGB_VFPD;
      		hdisplay.RGB_Init.HSPW = RGB_HSPW;
      		hdisplay.RGB_Init.VSPW = RGB_VSPW;
      		hdisplay.RGB_Init.HRES = RGB_ROW;
      		hdisplay.RGB_Init.VRES = RGB_COL;
      		display_init(&hdisplay);
      		/* RGB_CLK =  (PER_CLK_RGB / 5*2) */
          __DISPLAY_RGB_SET_PIXEL_CLK_DIV(hdisplay.DISPLAYx,8);
      		/* DMA Init */
       * @fn      rgb_demo
       * @brief   rgb demo
       * @param   fe_Demo: demo select.
      		rgb_panel_init();
          switch(fe_Demo)
              case RGB_INTERACTION:
      						printf("RGB demo: solid color start\r\n");
      //            dma_start(&dma_handle,(uint32_t)(display_psram_buff),(uint32_t)&hdisplay.DISPLAYx->TX_FIFO, RGB_ROW * RGB_COL);
      //						while(!dma_get_tfr_Status(&dma_handle));
      //            dma_clear_tfr_Status(&dma_handle);
      						break;
      						uint16_t buffl[64];
                  break;
      		void * temp = NULL;
      		g_dma0_irq_cnt++;
      //        if(refr_wait_sign)
      //            __DISPLAY_RGB_DISABLE(hdisplay.DISPLAYx);
      //        else
      //            __DISPLAY_RGB_ENABLE(hdisplay.DISPLAYx);
      //            dma_start_IT(&dma_handle,(uint32_t)display_psram_buff,(uint32_t)&hdisplay.DISPLAYx->TX_FIFO, RGB_ROW * RGB_COL);
      		g_dma0_irq_cnt++;
      发布在 FR306x
      L
      lakesky
    • FR3068E-D开发板驱动RGB屏幕问题
      开发板驱动开发板配套屏幕 驱动异常 参考例程:display 按照 display_dome.c内的驱动例程去驱动800480屏幕
      由于800
      480的数据太大故分包发送
      相关配置如下
      发送函数:
      尝试过多种方式当时都存在异常要么只亮背光、要么颜色跟传输颜色不一致
      使用逻辑分析仪读信号 hs vs de pclk 均有信号(高低电平) disp正常为高 但是抓取lcd-G4 却一直高
      太异常了 屏幕规格书上时序为de模式 fr306x的参考手册写明了是支持de模式的
      传输数据的函数(修改过):
      发布在 FR306x
      L
      lakesky
