Cannot enable 2Mb phy mode
After AUX_CONNECT_RSP, mcu send LL_PHY_REQ with 1mbps phy. Advertising goes with 2mbps phy. Could you help how to select 2mbps phy? Image with sniffered ble packets is attached. Advertising parameters:
gap_adv_param_t adv_param = {0}; adv_param.adv_mode = GAP_ADV_MODE_EXTEND_CONN_UNDIRECT; adv_param.adv_addr_type = GAP_ADDR_TYPE_PUBLIC; adv_param.phy_mode = GAP_PHY_2MBPS; adv_param.adv_chnl_map = GAP_ADV_CHAN_ALL; adv_param.adv_filt_policy = GAP_ADV_ALLOW_SCAN_ANY_CON_ANY; adv_param.adv_intv_min = 600; adv_param.adv_intv_max = 600; adv_param.disc_mode = GAP_ADV_DISC_MODE_GEN_DISC; adv_param.adv_sid = 0x2;Also I try to update phy after connect event:
case GAP_EVT_SLAVE_CONNECT: { co_printf("Connected\r\n"); connidx = p_event->param.slave_connect.conidx; gap_conn_phy_update(connidx, GAP_PHY_2MBPS, GAP_PHY_2MBPS); os_timer_start(&update_param_timer,4000,0); ble_fts_on_connected(); tlakepro_service_on_connected(); main_task_send_connected_event(); } break;
@eldar 在 Cannot enable 2Mb phy mode 中说:
like this,gap_conn_phy_update(connidx, GAP_PHY_2MBPS, GAP_PHY_2MBPS);
