flash_protect_enable问题
/********************************************************************* * @fn flash_protect_enable * * @brief protect flash chip from erase and write. * * @param wr_mode - 0: write.enable with command 0x50 * 1: write enable with command 0x06 * * @return None. */ __attribute__((section("ram_code"))) void flash_protect_enable(uint8_t wr_mode); /********************************************************************* * @fn flash_protect_enable1 * * @brief protect flash chip from erase and write. * * @param wr_mode - 0: write.enable with command 0x50 * 1: write enable with command 0x06 * mask protect bits mask, refer to flash spec * * @return None. */ __attribute__((section("ram_code"))) void flash_protect_enable1(uint8_t wr_mode,uint8_t mask); /********************************************************************* * @fn flash_protect_disable * * @brief remove protection flash chip from erase and write. * * @param wr_mode - 0: write.enable with command 0x50 * 1: write enable with command 0x06 * * @return None. */ __attribute__((section("ram_code"))) void flash_protect_disable(uint8_t wr_mode);
flash_protect_enable和flash_protect_enable1有什么区别吗?
@uplooking 不建议用flash_protect_enable1,正常就用flash_protect_enable就好,wr_mode 0代表易失,1代表非易失,一般上电先flash_protect_enable(1)进行flash保护,中间需要擦写flash时就flash_protect_disable(0),操作完成就flash_protect_enable(0)恢复保护
此回复已被删除!
