FR3036D例程使用debug的时候卡在初始化阶段
linking...
..\src\Platform_abstraction\third_party\components\toolchain\armcc\fr101x_flash.sct(31): warning: L6314W: No section matches pattern *btdm_controller.lib(ZI).
..\src\Platform_abstraction\third_party\components\toolchain\armcc\fr101x_flash.sct(31): warning: L6314W: No section matches pattern *btdm_controller.lib(RW).
..\src\Platform_abstraction\third_party\components\toolchain\armcc\fr101x_flash.sct(43): warning: L6314W: No section matches pattern *(NOINIT).
Program Size: Code=293752 RO-data=48372 RW-data=18080 ZI-data=45544
Finished: 0 information, 3 warning and 0 error messages.
After Build - User command #1: "..\src\Platform_abstraction\third_party\components\toolchain\armcc\post_process.bat" "ble_simple_periphreal" "D:\Work_space\Engineering_Code\BLE-BR1601A01\BLE-FR\keil\Objects\ble_simple_periphreal.axf" "D:\Work_space\Application\Keil\ARM\ARMCLANG\include"
20261125
10:51:05.42
program target with file D:\Work_space\Engineering_Code\BLE-BR1601A01\BLE-FR\keil\output\ble_simple_periphreal_burn.bin
".\Objects\ble_simple_periphreal.axf" - 0 Error(s), 3 Warning(s).
Build Time Elapsed: 00:00:17
我把这个宏直接移到代码里,程序一直在while里,但是对应寄存器#define QSPI_APB_BASE (0x500C8000)这个里面的数据显示这一位是1.但是就是一直在while里,这是我的sct
ROM 0x10002000 0x100000
ER_RO 0x10002000
startup_fr1010.o (RESET, +FIRST)
*(+RO)
}RAM_CODE 0x1FFFC000 0x3f80 { *(ram_code) } APP_PRAM_DATA +0 { *(app_pram_data) } LTE_RX_BUFFER +0 UNINIT 0x1000 { *(lte_rx_buffer) } PATCH_TABLE 0x20001c80 { *(patch_table) } HOST_DATA +0 { *btdm_controller.lib (+ZI, +RW) *btdm_host.lib (+ZI, +RW) } ER_RW +0 { *(+RW) *(+ZI) } ER_RW_1 +0 UNINIT { *(NOINIT) *(.bss.NoInit) } ScatterAssert(ImageLength(APP_PRAM_DATA) <= 0x0a00) ScatterAssert((ImageLength(RAM_CODE) + ImageLength(APP_PRAM_DATA) + ImageLength(LTE_RX_BUFFER)) <= 0x3f80) ScatterAssert((ImageLength(PATCH_TABLE)+ImageLength(HOST_DATA) + ImageLength(ER_RW) + ImageLength(ER_RW_1)) <= 0xe380)}
希望更给一些方案排查出问题在哪。
@fei
不debug情况下能跑嘛jlink配置是参考的手册配置的吗
